Re: 85 Honda Spree
> P D wrote:
> > S C wrote:
> > What I’m curious about is whether opening the float bowl drain screw
> > will break the vacuum and just drain everything out of the line but
> not
> > allow any additional fuel from the petcock.
> > Regardless it seems theres issues with either the bendix (starter
> > pinion) or drive belt components. Cranking it over the starter isn’t
> > spinning the wheel fast enough to get it going and just binds down.
> > Almost has that low battery sound but does same thing when hooked up
> to
> > jumper cables. I’ll take the pinion off and wire brush clean it out,
> > regrease it and remove the belt to see if that makes a difference in
> > speed of the starter. Gotta be something to tight to allow it to spin.
> The vacuum chamber is not affected by drainage of the bowl . As long as
> there's vacuum , either via the motor running or your mouth , fuel will
> flow . The valve is spring loaded and presses closed when no vacuum is
> present .
> Your slow turn over may be caused by a dirty starter motor .
> Pull it . Tear it apart and clean the internals . Lightly lube the
> bearings / sleeves for the armature and put it back together .
Ah cool didn’t know that about the vacuum.
Yeah I’m going to pull the bendix, and starter to clean both and regrease. Might be rusty or something. The gear the bendix connects with is definitely rusty so this thing probably sat out in the elements for awhile.
  85 Honda SpreeTopic by: S C S C 10/11/21 09:50AM
  Re: 85 Honda SpreeRe: Stephen Keller Stephen Keller 10/11/21 11:18AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/11/21 12:15PM
  Re: 85 Honda SpreeRe: Stephen Keller Stephen Keller 10/11/21 12:37PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 12:42PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/11/21 02:28PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 06:32PM
  Re: 85 Honda SpreeRe: Chad Tufts Chad Tufts 10/11/21 01:52PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/11/21 03:13PM
  Re: 85 Honda SpreeRe: P D P D 10/11/21 04:26PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 06:35PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/11/21 07:54PM
  Re: 85 Honda SpreeRe: S C S C 10/12/21 08:01PM
  Re: 85 Honda SpreeRe: P D P D 10/12/21 08:20PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 07:15AM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 10:47AM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 11:36AM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 12:44PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 01:36PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 03:37PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 07:09PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 07:40PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 08:26PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 09:04PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/13/21 02:26PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 02:41PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 09:50PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 12:51PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/15/21 12:29AM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 07:54AM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 05:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/15/21 06:17PM
  Re: 85 Honda SpreeRe: P D P D 10/15/21 06:41PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/15/21 09:34PM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 07:52PM
  Re: 85 Honda SpreeRe: Luna Moto Luna Moto 10/11/21 04:25PM
  Re: 85 Honda SpreeRe: Born to be WillD Born to be WillD 10/12/21 12:16PM
  Re: 85 Honda SpreeRe: Born to be WillD Born to be WillD 10/12/21 12:17PM
  Re: 85 Honda SpreeRe: S C S C 10/12/21 03:08PM
  Re: 85 Honda SpreeRe: Pushrod Fifty Pushrod Fifty 10/12/21 11:23AM
  Re: 85 Honda SpreeRe: punkrock randy punkrock randy 10/13/21 07:25AM
  Re: 85 Honda SpreeRe: Gerry F Gerry F 10/14/21 02:49PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 03:48PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 04:12PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 04:28PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 04:55PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 05:25PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 08:03PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 08:23PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 08:20AM
  Re: 85 Honda SpreeRe: Garelli Master✨ Garelli Master✨ 10/16/21 09:28AM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 10:02AM
  Re: 85 Honda SpreeRe: Garelli Master✨ Garelli Master✨ 10/14/21 09:04PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 03:28PM
  Re: 85 Honda SpreeRe: Garelli Master✨ Garelli Master✨ 10/16/21 04:12PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 08:37PM
  Re: 85 Honda SpreeRe: S C S C 10/18/21 09:18PM
  Re: 85 Honda SpreeRe: Sean Volpe Sean Volpe 10/19/21 12:10AM
  Re: 85 Honda SpreeRe: S C S C 10/19/21 06:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/20/21 09:35AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/20/21 09:38AM
  Re: 85 Honda SpreeRe: S C S C 10/20/21 02:08PM
  Re: 85 Honda SpreeRe: S C S C 11/03/21 10:33AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 10:58AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 11:03AM
  Re: 85 Honda SpreeRe: S C S C 11/03/21 03:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 09:46PM
  Re: 85 Honda SpreeRe: S C S C 11/06/21 11:04PM
  Re: 85 Honda SpreeRe: Gerry F Gerry F 11/10/21 04:33PM
  Re: 85 Honda SpreeRe: S C S C 11/10/21 06:12PM
  Re: 85 Honda SpreeRe: Satan 666 Satan 666 11/10/21 09:29PM
