Re: 85 Honda Spree
P D /
> S C wrote:
> What I’m curious about is whether opening the float bowl drain screw
> will break the vacuum and just drain everything out of the line but not
> allow any additional fuel from the petcock.
> Regardless it seems theres issues with either the bendix (starter
> pinion) or drive belt components. Cranking it over the starter isn’t
> spinning the wheel fast enough to get it going and just binds down.
> Almost has that low battery sound but does same thing when hooked up to
> jumper cables. I’ll take the pinion off and wire brush clean it out,
> regrease it and remove the belt to see if that makes a difference in
> speed of the starter. Gotta be something to tight to allow it to spin.
The vacuum chamber is not affected by drainage of the bowl . As long as there's vacuum , either via the motor running or your mouth , fuel will flow . The valve is spring loaded and presses closed when no vacuum is present .
Your slow turn over may be caused by a dirty starter motor .
Pull it . Tear it apart and clean the internals . Lightly lube the bearings / sleeves for the armature and put it back together .
  85 Honda SpreeTopic by: S C S C 10/11/21 09:50AM
  Re: 85 Honda SpreeRe: Stephen Keller Stephen Keller 10/11/21 11:18AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/11/21 12:15PM
  Re: 85 Honda SpreeRe: Stephen Keller Stephen Keller 10/11/21 12:37PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 12:42PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/11/21 02:28PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 06:32PM
  Re: 85 Honda SpreeRe: Chad Tufts Chad Tufts 10/11/21 01:52PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/11/21 03:13PM
  Re: 85 Honda SpreeRe: P D P D 10/11/21 04:26PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 06:35PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/11/21 07:54PM
  Re: 85 Honda SpreeRe: S C S C 10/12/21 08:01PM
  Re: 85 Honda SpreeRe: P D P D 10/12/21 08:20PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 07:15AM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 10:47AM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 11:36AM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 12:44PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 01:36PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 03:37PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 07:09PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 07:40PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 08:26PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 09:04PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/13/21 02:26PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 02:41PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 09:50PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 12:51PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/15/21 12:29AM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 07:54AM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 05:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/15/21 06:17PM
  Re: 85 Honda SpreeRe: P D P D 10/15/21 06:41PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/15/21 09:34PM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 07:52PM
  Re: 85 Honda SpreeRe: Luna Moto Luna Moto 10/11/21 04:25PM
  Re: 85 Honda SpreeRe: Born to be WillD Born to be WillD 10/12/21 12:16PM
  Re: 85 Honda SpreeRe: Born to be WillD Born to be WillD 10/12/21 12:17PM
  Re: 85 Honda SpreeRe: S C S C 10/12/21 03:08PM
  Re: 85 Honda SpreeRe: Pushrod Fifty Pushrod Fifty 10/12/21 11:23AM
  Re: 85 Honda SpreeRe: punkrock randy punkrock randy 10/13/21 07:25AM
  Re: 85 Honda SpreeRe: Gerry F Gerry F 10/14/21 02:49PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 03:48PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 04:12PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 04:28PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 04:55PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 05:25PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 08:03PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 08:23PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 08:20AM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/16/21 09:28AM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 10:02AM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/14/21 09:04PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 03:28PM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/16/21 04:12PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 08:37PM
  Re: 85 Honda SpreeRe: S C S C 10/18/21 09:18PM
  Re: 85 Honda SpreeRe: Sean Volpe Sean Volpe 10/19/21 12:10AM
  Re: 85 Honda SpreeRe: S C S C 10/19/21 06:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/20/21 09:35AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/20/21 09:38AM
  Re: 85 Honda SpreeRe: S C S C 10/20/21 02:08PM
  Re: 85 Honda SpreeRe: S C S C 11/03/21 10:33AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 10:58AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 11:03AM
  Re: 85 Honda SpreeRe: S C S C 11/03/21 03:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 09:46PM
  Re: 85 Honda SpreeRe: S C S C 11/06/21 11:04PM
  Re: 85 Honda SpreeRe: Gerry F Gerry F 11/10/21 04:33PM
  Re: 85 Honda SpreeRe: S C S C 11/10/21 06:12PM
  Re: 85 Honda SpreeRe: Satan 666 Satan 666 11/10/21 09:29PM
