Re: 85 Honda Spree
> P D wrote:
> > S C wrote:
> > > Kenny Shinneman wrote:
> > > I did use an inline filter but no shut off valve. Just confirmed the
> > new
> > > Petcock shut off completely when at rest.
> > So I ‘reset’ the vacuum diapraghm in the petcock per the manual and
> hit
> > it with compressed air from the top. Replaced it, connected the gas
> > line, then primed the vacuum line with negative pressure and fuel
> flowed
> > to the carb as expected. Reconnected the vacuum line then without it
> > running (doesn’t run yet), removed the fuel line and it drained out
> what
> > was in the line and stopped flowing. So the fuel issue for now seems
> to
> > be resolved. Next thing I’ll try is priming the fuel line and opening
> > the carb drain screw to see if the float is working or if it just
> pours
> > out the bottom.
> With the bowl drain open , there's no build up of fuel to close the
> valve . Fuel will simply keep flowing as long as the petcock allows .
> Better polish the float valve seat with q tips and Brasso or the like .
> It should be shiny clean with no deformations . Same goes for the float
> valve needle , if it's metal . If rubber tipped , it should be somewhat
> supple and conical with no deformation .
What I’m curious about is whether opening the float bowl drain screw will break the vacuum and just drain everything out of the line but not allow any additional fuel from the petcock.
Regardless it seems theres issues with either the bendix (starter pinion) or drive belt components. Cranking it over the starter isn’t spinning the wheel fast enough to get it going and just binds down. Almost has that low battery sound but does same thing when hooked up to jumper cables. I’ll take the pinion off and wire brush clean it out, regrease it and remove the belt to see if that makes a difference in speed of the starter. Gotta be something to tight to allow it to spin.
  85 Honda SpreeTopic by: S C S C 10/11/21 09:50AM
  Re: 85 Honda SpreeRe: Stephen Keller Stephen Keller 10/11/21 11:18AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/11/21 12:15PM
  Re: 85 Honda SpreeRe: Stephen Keller Stephen Keller 10/11/21 12:37PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 12:42PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/11/21 02:28PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 06:32PM
  Re: 85 Honda SpreeRe: Chad Tufts Chad Tufts 10/11/21 01:52PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/11/21 03:13PM
  Re: 85 Honda SpreeRe: P D P D 10/11/21 04:26PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 06:35PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/11/21 07:54PM
  Re: 85 Honda SpreeRe: S C S C 10/12/21 08:01PM
  Re: 85 Honda SpreeRe: P D P D 10/12/21 08:20PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 07:15AM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 10:47AM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 11:36AM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 12:44PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 01:36PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 03:37PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 07:09PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 07:40PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 08:26PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 09:04PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/13/21 02:26PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 02:41PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 09:50PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 12:51PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/15/21 12:29AM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 07:54AM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 05:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/15/21 06:17PM
  Re: 85 Honda SpreeRe: P D P D 10/15/21 06:41PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/15/21 09:34PM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 07:52PM
  Re: 85 Honda SpreeRe: Luna Moto Luna Moto 10/11/21 04:25PM
  Re: 85 Honda SpreeRe: Born to be WillD Born to be WillD 10/12/21 12:16PM
  Re: 85 Honda SpreeRe: Born to be WillD Born to be WillD 10/12/21 12:17PM
  Re: 85 Honda SpreeRe: S C S C 10/12/21 03:08PM
  Re: 85 Honda SpreeRe: Pushrod Fifty Pushrod Fifty 10/12/21 11:23AM
  Re: 85 Honda SpreeRe: punkrock randy punkrock randy 10/13/21 07:25AM
  Re: 85 Honda SpreeRe: Gerry F Gerry F 10/14/21 02:49PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 03:48PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 04:12PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 04:28PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 04:55PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 05:25PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 08:03PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 08:23PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 08:20AM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/16/21 09:28AM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 10:02AM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/14/21 09:04PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 03:28PM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/16/21 04:12PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 08:37PM
  Re: 85 Honda SpreeRe: S C S C 10/18/21 09:18PM
  Re: 85 Honda SpreeRe: Sean Volpe Sean Volpe 10/19/21 12:10AM
  Re: 85 Honda SpreeRe: S C S C 10/19/21 06:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/20/21 09:35AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/20/21 09:38AM
  Re: 85 Honda SpreeRe: S C S C 10/20/21 02:08PM
  Re: 85 Honda SpreeRe: S C S C 11/03/21 10:33AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 10:58AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 11:03AM
  Re: 85 Honda SpreeRe: S C S C 11/03/21 03:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 09:46PM
  Re: 85 Honda SpreeRe: S C S C 11/06/21 11:04PM
  Re: 85 Honda SpreeRe: Gerry F Gerry F 11/10/21 04:33PM
  Re: 85 Honda SpreeRe: S C S C 11/10/21 06:12PM
  Re: 85 Honda SpreeRe: Satan 666 Satan 666 11/10/21 09:29PM
