Re: 85 Honda Spree
P D /
> S C wrote:
> > Kenny Shinneman wrote:
> > I did use an inline filter but no shut off valve. Just confirmed the
> new
> > Petcock shut off completely when at rest.
> So I ‘reset’ the vacuum diapraghm in the petcock per the manual and hit
> it with compressed air from the top. Replaced it, connected the gas
> line, then primed the vacuum line with negative pressure and fuel flowed
> to the carb as expected. Reconnected the vacuum line then without it
> running (doesn’t run yet), removed the fuel line and it drained out what
> was in the line and stopped flowing. So the fuel issue for now seems to
> be resolved. Next thing I’ll try is priming the fuel line and opening
> the carb drain screw to see if the float is working or if it just pours
> out the bottom.
With the bowl drain open , there's no build up of fuel to close the valve . Fuel will simply keep flowing as long as the petcock allows .
Better polish the float valve seat with q tips and Brasso or the like . It should be shiny clean with no deformations . Same goes for the float valve needle , if it's metal . If rubber tipped , it should be somewhat supple and conical with no deformation .
  85 Honda SpreeTopic by: S C S C 10/11/21 09:50AM
  Re: 85 Honda SpreeRe: Stephen Keller Stephen Keller 10/11/21 11:18AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/11/21 12:15PM
  Re: 85 Honda SpreeRe: Stephen Keller Stephen Keller 10/11/21 12:37PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 12:42PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/11/21 02:28PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 06:32PM
  Re: 85 Honda SpreeRe: Chad Tufts Chad Tufts 10/11/21 01:52PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/11/21 03:13PM
  Re: 85 Honda SpreeRe: P D P D 10/11/21 04:26PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 06:35PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/11/21 07:54PM
  Re: 85 Honda SpreeRe: S C S C 10/12/21 08:01PM
  Re: 85 Honda SpreeRe: P D P D 10/12/21 08:20PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 07:15AM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 10:47AM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 11:36AM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 12:44PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 01:36PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 03:37PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 07:09PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 07:40PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 08:26PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 09:04PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/13/21 02:26PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 02:41PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 09:50PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 12:51PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/15/21 12:29AM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 07:54AM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 05:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/15/21 06:17PM
  Re: 85 Honda SpreeRe: P D P D 10/15/21 06:41PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/15/21 09:34PM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 07:52PM
  Re: 85 Honda SpreeRe: Luna Moto Luna Moto 10/11/21 04:25PM
  Re: 85 Honda SpreeRe: Born to be WillD Born to be WillD 10/12/21 12:16PM
  Re: 85 Honda SpreeRe: Born to be WillD Born to be WillD 10/12/21 12:17PM
  Re: 85 Honda SpreeRe: S C S C 10/12/21 03:08PM
  Re: 85 Honda SpreeRe: Pushrod Fifty Pushrod Fifty 10/12/21 11:23AM
  Re: 85 Honda SpreeRe: punkrock randy punkrock randy 10/13/21 07:25AM
  Re: 85 Honda SpreeRe: Gerry F Gerry F 10/14/21 02:49PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 03:48PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 04:12PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 04:28PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 04:55PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 05:25PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 08:03PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 08:23PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 08:20AM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/16/21 09:28AM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 10:02AM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/14/21 09:04PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 03:28PM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/16/21 04:12PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 08:37PM
  Re: 85 Honda SpreeRe: S C S C 10/18/21 09:18PM
  Re: 85 Honda SpreeRe: Sean Volpe Sean Volpe 10/19/21 12:10AM
  Re: 85 Honda SpreeRe: S C S C 10/19/21 06:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/20/21 09:35AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/20/21 09:38AM
  Re: 85 Honda SpreeRe: S C S C 10/20/21 02:08PM
  Re: 85 Honda SpreeRe: S C S C 11/03/21 10:33AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 10:58AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 11:03AM
  Re: 85 Honda SpreeRe: S C S C 11/03/21 03:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 09:46PM
  Re: 85 Honda SpreeRe: S C S C 11/06/21 11:04PM
  Re: 85 Honda SpreeRe: Gerry F Gerry F 11/10/21 04:33PM
  Re: 85 Honda SpreeRe: S C S C 11/10/21 06:12PM
  Re: 85 Honda SpreeRe: Satan 666 Satan 666 11/10/21 09:29PM
