When it happened to me I took the engine out and turned it upside down to drain it. Your carb float needle is probably bad. The rubber tip or aluminum tip is worn, letting gas run through unchecked. Check for a crankcase drain screw. If you remove the pipe you can crank it over with sparkplug in but disconnected, a pan underneath with the gas line pinched off to get most the gas out.
