Re: Parmakit cdi box not retarding
LSLB RXb /
so alright, the parmakits start low, the way you are seeing it at idle. then at boosted RPMs before the curve hits, they advance, and then the retard back to about where it starts at idle, maybe a little bit more advanced then where it idles.
so to say, idle will be around 8 degrees BTDC for easy starting and idle, 2000 - 6000 rpms will be maybe 20 degrees BTDC, 6000 - 10000 rpms will be 12 degrees.
i've always had good luck with these even running them on stuff you aren't supposed to. maybe you got a bad one, but several people here who have used several of them vouch for them.
Also we've seen them make bikes run backwards when the spade connectors get flipped. don't do that....
The one that I'm running on my tomos that fully has a curve is numbered 82 48/19 which i read as part of the 82 batch of the year, produced on the 48th week of the 19th year of 2000. that would mean yours is batch 66 produced on the 25th week of the 21st year 2000. might be useful for tracking down a problem, but my guess is that you just aren't revving high enough to see the curve retard once it starts to move back.
also, a lot of timing lights are only rated to like 10k or 12k, which on these CDIs that fire twice every 360ยบ of rotation equates to only accurate readings up to 5k - 6k which really just isn't enough.
  Parmakit cdi box not retardingTopic by: Wolf Wizard Wolf Wizard 10/10/21 12:31AM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/10/21 08:25AM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/10/21 04:15PM
  Re: Parmakit cdi box not retardingRe: P D P D 10/10/21 07:49PM
  Re: Parmakit cdi box not retardingRe: Totally normal JBOT Totally normal JBOT 10/15/21 11:32AM
  Re: Parmakit cdi box not retardingRe: Richard Eberline Richard Eberline 10/10/21 07:10PM
  Re: Parmakit cdi box not retardingRe: Dirty30 Dillon Dirty30 Dillon 10/10/21 09:39PM
  Re: Parmakit cdi box not retardingRe: EH FCC of the QCB EH FCC of the QCB 10/10/21 10:54PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/11/21 12:32AM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/11/21 07:14PM
  Re: Parmakit cdi box not retardingRe: campeona del mundo campeona del mundo 10/11/21 07:47PM
  Re: Parmakit cdi box not retardingRe: todd amundson todd amundson 10/11/21 07:51PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/11/21 08:06PM
  Re: Parmakit cdi box not retardingRe: Conan Segar Conan Segar 10/11/21 08:20PM
  Re: Parmakit cdi box not retardingRe: Graham Motzing Graham Motzing 10/12/21 08:51PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/11/21 09:44PM
  Re: Parmakit cdi box not retardingRe: campeona del mundo campeona del mundo 10/12/21 12:20PM
  Re: Parmakit cdi box not retardingRe: Dave & Bummerzz Dave & Bummerzz 10/12/21 12:47PM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/12/21 05:50PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/12/21 11:05PM
  Re: Parmakit cdi box not retardingRe: Dave & Bummerzz Dave & Bummerzz 10/13/21 09:30AM
  Re: Parmakit cdi box not retardingRe: Graham Motzing Graham Motzing 10/13/21 01:59PM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/13/21 10:24PM
  Re: Parmakit cdi box not retardingRe: Dirty30 Dillon Dirty30 Dillon 10/13/21 09:49AM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/12/21 05:53PM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/12/21 06:59PM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/12/21 07:09PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/16/21 12:36AM
  Re: Parmakit cdi box not retardingRe: pat splat pat splat 10/16/21 11:02AM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/16/21 11:47AM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/12/21 09:11PM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/13/21 10:37PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/12/21 09:37PM
  Re: Parmakit cdi box not retardingRe: Ryan Nash Ryan Nash 10/13/21 06:10AM
  Re: Parmakit cdi box not retardingRe: Born to be WillD Born to be WillD 10/13/21 12:59PM
  Re: Parmakit cdi box not retardingRe: Graham Motzing Graham Motzing 10/13/21 11:50PM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/14/21 12:42AM
  Re: Parmakit cdi box not retardingRe: ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin 10/14/21 07:19AM
  Re: Parmakit cdi box not retardingRe: Daniel '' Daniel '' 10/16/21 03:37PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/14/21 08:08PM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/15/21 10:06AM
  Re: Parmakit cdi box not retardingRe: campeona del mundo campeona del mundo 10/15/21 12:37PM
  Re: Parmakit cdi box not retardingRe: b to the eff b to the eff 10/15/21 02:44PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/15/21 05:07PM
  Re: Parmakit cdi box not retardingRe: Totally normal JBOT Totally normal JBOT 10/15/21 11:25PM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/16/21 11:38AM
  Re: Parmakit cdi box not retardingRe: b to the eff b to the eff 10/17/21 11:51AM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/17/21 01:09PM
  Re: Parmakit cdi box not retardingRe: b to the eff b to the eff 10/18/21 12:55PM
  Re: Parmakit cdi box not retardingRe: Graham Motzing Graham Motzing 10/18/21 02:06PM
  Re: Parmakit cdi box not retardingRe: campeona del mundo campeona del mundo 10/15/21 05:13PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/15/21 07:38PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/15/21 11:21PM
  Re: Parmakit cdi box not retardingRe: Dirty30 Dillon Dirty30 Dillon 10/16/21 09:37PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/17/21 01:48AM
  Re: Parmakit cdi box not retardingRe: Graham Motzing Graham Motzing 10/17/21 02:21PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/15/21 11:53PM
  Re: Parmakit cdi box not retardingRe: pat splat pat splat 10/16/21 12:27AM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/16/21 01:16PM
  Re: Parmakit cdi box not retardingRe: campeona del mundo campeona del mundo 10/16/21 08:35PM
  Re: Parmakit cdi box not retardingRe: Ryan Nash Ryan Nash 10/17/21 07:57AM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/27/21 10:26PM
  Re: Parmakit cdi box not retardingRe: Daniel '' Daniel '' 10/27/21 10:39PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/27/21 10:46PM
  Re: Parmakit cdi box not retardingRe: Graham Motzing Graham Motzing 10/27/21 11:08PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/27/21 11:15PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 10/27/21 11:16PM
  Re: Parmakit cdi box not retardingRe: ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin 10/28/21 02:41AM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 10/29/21 12:37PM
  Re: Parmakit cdi box not retardingRe: Zach G. Zach G. 12/17/21 10:14PM
  Re: Parmakit cdi box not retardingRe: Zach G. Zach G. 12/17/21 10:52PM
  Re: Parmakit cdi box not retardingRe: Zach G. Zach G. 12/18/21 12:30AM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 12/18/21 12:45AM
  Re: Parmakit cdi box not retardingRe: Zach G. Zach G. 12/18/21 12:16PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 12/20/21 03:55PM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 12/20/21 06:57PM
  Re: Parmakit cdi box not retardingRe: LSLB RXb LSLB RXb 12/20/21 07:04PM
  Re: Parmakit cdi box not retardingRe: Papa _ Papa _ 12/20/21 07:22PM
  Re: Parmakit cdi box not retardingRe: Wolf Wizard Wolf Wizard 12/20/21 09:53PM
  Re: Parmakit cdi box not retardingRe: ๐ŸŽจ๐Ÿ† Duncan ๐ŸŽจ๐Ÿ† Duncan 12/21/21 06:48AM
