Re: Hobbit stage 6
Not everything in this guide will apply, but it's a great place to start: https://www.mopedarmy.com/wiki/Fred%27s_Guide
Good luck!
Re: Hobbit stage 6
Edward Rosario /
Noticed the one of the crank seal was gone. Ordered a new one. I checked the piston and it’s in the right direction. Once I get the new seal In, I’ll pressure test and time with the gun. Thanks for the info. It really helped me out finding out one problem
Re: Hobbit stage 6
Edward Rosario /
Much appreciated
Re: Hobbit stage 6
BTW... What's holding that pipe in place? Typically these pipes have two points of attachment on a Hobbit one is up front but there's also going to be another one to the subframe which is what I'm pointing to. Whether or not the pipe that's on this water cooler Will survive long rides with vibration I don't know I picked this up from a land squitter who I think she wanted at a contest she had really sweet graphics on her ride. I was just wondering whether by some chance it was attached to the upper part of the body that's above the shocks I don't know it could be just an optical illusion but if it is....
Re: Hobbit stage 6
Edward Rosario /
The person who welded it did not know what they was doing. I asked for one thing and got another. Once it’s running I’ll have it shortened
Re: Hobbit stage 6
I'm not talking about that length... I'm talking about the second point of attachment of the pipe.
Re: Hobbit stage 6
He's saying that if you even sit on this bike with the exhaust pipe mounted like it is, it is going to either break the studs that hold the pipe on or the pipe itself. You can't mount the pipe to the frame since the entire motor/subframe assembly pivots on the frame, ya dig?
Re: Hobbit stage 6
Edward Rosario /
The fabricator welded it like that. It was no supposed to go there. That bracket is going on the subframe
Re: Hobbit stage 6
Tweaker trash /
Dude stop trolling
