Re: Hobbit stage 6
Edward Rosario /
Update,
Yes, I am way in over my head, so I been researching and thanks to all that gave me advise on what to check for. The exhaust was welded that way. So that’s getting shortened as soon as I get it running. The trolls 😘 what can I say, i understand you need the entertainment. I know for a fact at one point you was as inexperience and ignorant as me lol nothing but love here.
1. Bolt on fly wheel is to be able to crank it. Impossible to crank with the pulley on.
2. Radiator not hooked up focused on starting it.
3.started going thru the engine and found dio reed adapter gasket didn’t look too good so ordered a new one, and reed block was cracked so I replaced it had one laying around.
4. Took the ignition off And found that the ignition side seal is leaking so I ordered new crankshaft seals. And it was pushed way to in it did not sit flush (thanks Daniel)
5. HPI instructions are horrible so I might of been using the wrong point. On the flywheel.
6. Definitely destroyed the flywheel trying to
Crank it. I order a new one from treats but the one they sent me didn’t fit. Also waiting on that.
7. I also Learned how to use a timing gun “you tube”
8. engine was not put together by me (thank god or whatever you believe in lol) A friend of mines put it together and he has built me a super fast moby. Unfortunately he is not available to finish the build.
10. I also have a mukuni 24mm that I have tried on it as well And no luck.
So I bought a compression test kit, ordered new seals And a clutch puller, once I install the new seals and intake gasket. I’ll check the timing with the gun
Set up
1. Stage6 rt water cooled kit/with hobbit adapter
2. Super stuffy crank with 12mm wrist pin
3.HPI inner rotor
4. Honda dio reed kit
5. MLM intake
6.yellow clutch springs
7.rear “stock”
8. Case machined to fit kit. (edited)
  Hobbit stage 6Topic by: Edward Rosario Edward Rosario 10/02/21 03:36PM
  Re: Hobbit stage 6Re: Jackerz ! Jackerz ! 10/02/21 04:04PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/02/21 04:17PM
  Re: Hobbit stage 6Re: operator error 696 420 operator error 696 420 10/02/21 08:08PM
  Re: Hobbit stage 6Re: pat splat pat splat 10/03/21 12:26AM
  Re: Hobbit stage 6Re: operator error 696 420 operator error 696 420 10/03/21 08:59AM
  Re: Hobbit stage 6Re: Brandon . Brandon . 10/03/21 05:29AM
  Re: Hobbit stage 6Re: Daniel '' Daniel '' 10/03/21 12:14PM
  Re: Hobbit stage 6Re: Dirty30 Dillon Dirty30 Dillon 10/03/21 02:06PM
  Re: Hobbit stage 6Re: Daniel '' Daniel '' 10/03/21 05:46PM
  Re: Hobbit stage 6Re: Satan 666 Satan 666 10/03/21 06:45PM
  Re: Hobbit stage 6Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/04/21 07:29AM
  Re: Hobbit stage 6Re: Beach Club Nick Beach Club Nick 10/04/21 09:39AM
  Re: Hobbit stage 6Re: Daniel '' Daniel '' 10/04/21 10:14AM
  Re: Hobbit stage 6Re: Born to be WillD Born to be WillD 10/06/21 10:33AM
  Re: Hobbit stage 6Re: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/06/21 10:04AM
  Re: Hobbit stage 6Re: Marc Friedman Marc Friedman 10/03/21 03:55PM
  Re: Hobbit stage 6Re: Mikey McScoutington Mikey McScoutington 10/04/21 07:59AM
  Re: Hobbit stage 6Re: Brandon . Brandon . 10/04/21 09:35AM
  Re: Hobbit stage 6Re: operator error 696 420 operator error 696 420 10/04/21 09:58AM
  Re: Hobbit stage 6Re: Jesse Stephenson Jesse Stephenson 10/05/21 10:40PM
  Re: Hobbit stage 6Re: FUCKN JBOT FUCKN JBOT 10/06/21 12:12PM
  Re: Hobbit stage 6Re: Born to be WillD Born to be WillD 10/12/21 12:13PM
  Re: Hobbit stage 6Re: Travis Noll Travis Noll 10/05/21 11:14PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/12/21 12:58PM
  Re: Hobbit stage 6Re: Marc Friedman Marc Friedman 10/12/21 01:06PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/12/21 01:35PM
  Re: Hobbit stage 6Re: Marc Friedman Marc Friedman 10/12/21 02:38PM
  Re: Hobbit stage 6Re: Beach Club Nick Beach Club Nick 10/12/21 02:41PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/12/21 03:22PM
  Re: Hobbit stage 6Re: operator error 696 420 operator error 696 420 10/12/21 06:38PM
  Re: Hobbit stage 6Re: Graham Motzing Graham Motzing 10/16/21 09:38PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/16/21 09:52PM
  Re: Hobbit stage 6Re: operator error 696 420 operator error 696 420 10/17/21 12:06AM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/17/21 10:19AM
  Re: Hobbit stage 6Re: Shane Rickert Shane Rickert 10/17/21 04:59PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/12/21 10:38AM
  Re: Hobbit stage 6Re: FUCKN JBOT FUCKN JBOT 10/12/21 11:19AM
  Re: Hobbit stage 6Re: Mikey McScoutington Mikey McScoutington 10/12/21 11:39AM
  Re: Hobbit stage 6Re: operator error 696 420 operator error 696 420 10/12/21 11:53AM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/12/21 12:11PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/12/21 10:41AM
  Re: Hobbit stage 6Re: b to the eff b to the eff 10/12/21 12:45PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/12/21 01:02PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/16/21 03:19PM
  Re: Hobbit stage 6Re: Daniel '' Daniel '' 10/16/21 03:31PM
  Re: Hobbit stage 6Re: Marc Friedman Marc Friedman 10/16/21 06:36PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 10/16/21 08:18PM
  Re: Hobbit stage 6Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/17/21 02:40PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 03/14/22 10:41AM
  Re: Hobbit stage 6Re: operator error 696 420 operator error 696 420 03/14/22 12:16PM
  Re: Hobbit stage 6Re: Satan 666 Satan 666 03/14/22 01:29PM
  Re: Hobbit stage 6Re: Scottee doesn't know. Scottee doesn't know. 03/14/22 01:47PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 03/14/22 02:19PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 03/14/22 02:14PM
  Re: Hobbit stage 6Re: operator error 696 420 operator error 696 420 03/17/22 12:54AM
  Re: Hobbit stage 6Re: Nick / Ratbone Nick / Ratbone 03/14/22 09:23PM
  Re: Hobbit stage 6Re: Buttcheeks BUZZARD Buttcheeks BUZZARD 03/15/22 10:17AM
  Re: Hobbit stage 6Re: Dirty30 Dillon Dirty30 Dillon 03/15/22 12:45PM
  Re: Hobbit stage 6Re: Nick / Ratbone Nick / Ratbone 03/15/22 07:04PM
  Re: Hobbit stage 6Re: Dirty30 Dillon Dirty30 Dillon 03/15/22 07:22PM
  Re: Hobbit stage 6Re: Nick / Ratbone Nick / Ratbone 03/16/22 12:04AM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 03/16/22 08:13AM
  Re: Hobbit stage 6Re: Nick / Ratbone Nick / Ratbone 03/16/22 11:24AM
  Re: Hobbit stage 6Re: * wormdirt * * wormdirt * 03/16/22 05:06PM
  Re: Hobbit stage 6Re: operator error 696 420 operator error 696 420 03/17/22 12:57AM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 07/05/22 02:31PM
  Re: Hobbit stage 6Re: Mike Boyd Mike Boyd 07/05/22 02:37PM
  Re: Hobbit stage 6Re: Emil Kniemel Emil Kniemel 03/16/22 12:45PM
  Re: Hobbit stage 6Re: Nick / Ratbone Nick / Ratbone 03/16/22 02:38PM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 08/29/23 09:24PM
  Re: Hobbit stage 6Re: operator error 696 420 operator error 696 420 08/30/23 12:39AM
  Re: Hobbit stage 6Re: Edward Rosario Edward Rosario 08/31/23 10:52AM
