> Daniel '' wrote:
> Those maikuni tm24 Clone carbs are no good.
> Did you verify your timing with a light? Have you compression tested it?
> Leak down test? Did you press the ignition side seal in too far? I’ve
> seen that happen on more than one rebuild, I like to use the oem stator
> to set the seal to the right depth.
> There’s so many things going on here it would be hard to diagnose with
> the bike in front of me, but on the web it’s pretty much impossible.
