Re: Tomos Streetmate R Carb upgrade
Satan 666 /
> Jeffrey Rogalski wrote:
> I can tell it's faster and it's getting a lot more air now. when I took
> the stock one off it was all black and oozy. there is one problem I have
> is when I start is and pull the throttle it doesn't go anywhere and it
> just makes a loud dead sound but then it will kick on after a minute.
> Also, the guy I bought it from took off the oil thing so I mix the gas
> myself with the oil.
> I might have something lose and that's why I'm having this problem.
> Maybe its getting too much air
Not real familiar with tomos but if he deleted the oil injection did he plug the hole in the intake for the oil hose of it had one? If not you will have a big air leak. Did you rejet the carb after you pit on the new filter? If you change to a high flow filter you will have to richen up the main jet.
  Tomos Streetmate R Carb upgradeTopic by: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 01:08PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 01:24PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 01:31PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 02:00PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 02:22PM
  Re: Tomos Streetmate R Carb upgradeRe: Ryan Graeme Ryan Graeme 09/29/21 04:09PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 04:35PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/02/21 07:56PM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 10/03/21 12:22AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/04/21 01:26PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 01:47PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/04/21 02:21PM
  Re: Tomos Streetmate R Carb upgradeRe: Mike Boyd Mike Boyd 09/29/21 04:42PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 09/29/21 04:53PM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 09/29/21 07:34PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 09:21AM
  Re: Tomos Streetmate R Carb upgradeRe: Jesse Stephenson Jesse Stephenson 09/29/21 07:55PM
  Re: Tomos Streetmate R Carb upgradeRe: Aaron Blair Aaron Blair 09/30/21 10:23AM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 09/30/21 11:04AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 11:50AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 12:03PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 02:41PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 03:33PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/05/21 02:27PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/05/21 02:32PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/05/21 03:27PM
  Re: Tomos Streetmate R Carb upgradeRe: Conan Segar Conan Segar 10/11/21 08:30PM
  Re: Tomos Streetmate R Carb upgradeRe: Don Ohio Don Ohio 10/11/21 09:03PM
