Re: Tomos Streetmate R Carb upgrade
Jesse Stephenson /
So here is my fairly well researched take: put a 17.5mm PHVA on the bike, don't worry about doing anything to the intake at all, it's fine. Jetting with a pod filter will be around 20 idle, 40 slide, a7 needle, and around a 92 main jet, give or take. Swapping to the larger carb will not really net you much higher rpm ceiling but correct jetting will. Also gearing with the Streetmate is a bit wonky because of the larger tires so yea a 24T rear is equivalent to a 22t rear on a spring or otherwise. You don't need to switch back to stock stuff, just run what you already have, it's fine, It will vibrate more than stock but should pull a little harder with slightly higher top end rpm. Good luck!
  Tomos Streetmate R Carb upgradeTopic by: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 01:08PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 01:24PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 01:31PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 02:00PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 02:22PM
  Re: Tomos Streetmate R Carb upgradeRe: Ryan Graeme Ryan Graeme 09/29/21 04:09PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 04:35PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/02/21 07:56PM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 10/03/21 12:22AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/04/21 01:26PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 01:47PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/04/21 02:21PM
  Re: Tomos Streetmate R Carb upgradeRe: Mike Boyd Mike Boyd 09/29/21 04:42PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 09/29/21 04:53PM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 09/29/21 07:34PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 09:21AM
  Re: Tomos Streetmate R Carb upgradeRe: Jesse Stephenson Jesse Stephenson 09/29/21 07:55PM
  Re: Tomos Streetmate R Carb upgradeRe: Aaron Blair Aaron Blair 09/30/21 10:23AM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 09/30/21 11:04AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 11:50AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 12:03PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 02:41PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 03:33PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/05/21 02:27PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/05/21 02:32PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/05/21 03:27PM
  Re: Tomos Streetmate R Carb upgradeRe: Conan Segar Conan Segar 10/11/21 08:30PM
  Re: Tomos Streetmate R Carb upgradeRe: Don Ohio Don Ohio 10/11/21 09:03PM
