Re: Tomos Streetmate R Carb upgrade
Probably Fred /
Yeah that’s horrible performance for a kit and pipe, you should be at 45 mph at least!
Putting a bigger carburetor on it is not gonna do nothing if you have the stock 14-15mm ID intake
My stock cylinder revival (basically the same bike as a streetmate) Goes low to mid 40s with my 205-210 lb on it and that’s with no kit.
I’ve opened up the intake tract a little bit more and now I even got more low and takeoff then in the above video,
You need a retune/rejet your carburetor, run a metal mesh air filter, put a 24 tooth sprocket on the back, case match the kit to the ports in the engine block, open up the intake hole to match intake if smaller then intake, there’s a few other things you can do too but that’s a good start
  Tomos Streetmate R Carb upgradeTopic by: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 01:08PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 01:24PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 01:31PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 02:00PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 02:22PM
  Re: Tomos Streetmate R Carb upgradeRe: Ryan Graeme Ryan Graeme 09/29/21 04:09PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 04:35PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/02/21 07:56PM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 10/03/21 12:22AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/04/21 01:26PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 01:47PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/04/21 02:21PM
  Re: Tomos Streetmate R Carb upgradeRe: Mike Boyd Mike Boyd 09/29/21 04:42PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 09/29/21 04:53PM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 09/29/21 07:34PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 09:21AM
  Re: Tomos Streetmate R Carb upgradeRe: Jesse Stephenson Jesse Stephenson 09/29/21 07:55PM
  Re: Tomos Streetmate R Carb upgradeRe: Aaron Blair Aaron Blair 09/30/21 10:23AM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 09/30/21 11:04AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 11:50AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 12:03PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 02:41PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 03:33PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/05/21 02:27PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/05/21 02:32PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/05/21 03:27PM
  Re: Tomos Streetmate R Carb upgradeRe: Conan Segar Conan Segar 10/11/21 08:30PM
  Re: Tomos Streetmate R Carb upgradeRe: Don Ohio Don Ohio 10/11/21 09:03PM
