Re: Tomos Streetmate R Carb upgrade
Probably Fred /
Stock carb is a phva14 which = 14mm
A 17.5 carb will fit on stock intake but the stock intake is only 15 mm at its largest and cylinder intake hole can be only 14 mm
So you will need a aftermarket intake and dremel the cylinder intake hole to 17.5 mm.
You should be able to get low to mid 40s mph out of the stock 14mm carb with the right filter and pipe.
What is your set up and what is your speed?
  Tomos Streetmate R Carb upgradeTopic by: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 01:08PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 01:24PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 01:31PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 02:00PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/29/21 02:22PM
  Re: Tomos Streetmate R Carb upgradeRe: Ryan Graeme Ryan Graeme 09/29/21 04:09PM
  Re: Tomos Streetmate R Carb upgradeRe: Probably Fred Probably Fred 09/29/21 04:35PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/02/21 07:56PM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 10/03/21 12:22AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/04/21 01:26PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 01:47PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/04/21 02:21PM
  Re: Tomos Streetmate R Carb upgradeRe: Mike Boyd Mike Boyd 09/29/21 04:42PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 09/29/21 04:53PM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 09/29/21 07:34PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 09:21AM
  Re: Tomos Streetmate R Carb upgradeRe: Jesse Stephenson Jesse Stephenson 09/29/21 07:55PM
  Re: Tomos Streetmate R Carb upgradeRe: Aaron Blair Aaron Blair 09/30/21 10:23AM
  Re: Tomos Streetmate R Carb upgradeRe: pat splat pat splat 09/30/21 11:04AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 11:50AM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 09/30/21 12:03PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 02:41PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/04/21 03:33PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/05/21 02:27PM
  Re: Tomos Streetmate R Carb upgradeRe: Jeffrey Rogalski Jeffrey Rogalski 10/05/21 02:32PM
  Re: Tomos Streetmate R Carb upgradeRe: Satan 666 Satan 666 10/05/21 03:27PM
  Re: Tomos Streetmate R Carb upgradeRe: Conan Segar Conan Segar 10/11/21 08:30PM
  Re: Tomos Streetmate R Carb upgradeRe: Don Ohio Don Ohio 10/11/21 09:03PM
