Does anyone have moped exhausts in stock? Seems like MLM's have been out of stock for a while.
What moped?
He’s got a picture of a Champ on his page.
This is for a Yamaha Champ.
2 speed engine. Qt50 mlm pipe will need the rear bracket cut off, header bent (if possible), and bracket re-welded. Rear exhaust mounts are different. (edited)
When looking at parts fiche for QT50 and the Champ, the same part number is used for exhaust. I figured they were the same.
I know mj50 (2 peed motor) is different than qt50 (1 speed motor). the rear exhaust mount is like an extra inch from the centerline of the engine. This mlm edm circuit pipe is probably the best option as you can bend the rear mount and extend/fabricate rear bracket.
I put a tomos pipe on my mj50. I had to fabricate a bracket, but that was pretty easy.
> can
> was pretty easy.
How does this work?
Bolt it up and look where the rear mounts are. Then grab some tools and make it work.lol
> Billy Mild wrote:
> > Brian F wrote:
> the
> > can
> > was pretty easy.
> How does this work?
Pretty much. Attach pipe to cylinder. Take a piece of metal. Mark where you need to cut / drill holes. Do so and mount it up.
I had to add a couple of bends since the tomos pipe's rear mount kicks out a bit from the bike, but it only took a few minutes.
Pipes from other moped will fit the exhaust flange? I'm not too concerned with mounting yet I just want a pipe to fit the flange and clear the motor.
> clear the motor.
I had to grind the stud holes into slots, but yes.
> clear the motor.
Then the pipe I went with meets your criteria. QT50 MLM next level. For mounting on LC50 Champ that is. But nothing is available for ol’ Champ by name, too rare for attention.
