Re: 12v conversion question
b to the eff /
Tying both yellows together will short out the coil. Don't do that.
You have a couple of choices:
1) Grounded lighting coil: use the ring terminal on the right side of the coil to connect it to frame "ground", connect the other yellow wire on the coil to the yellow wire on the regulator. Connect the white or pink wire on the regulator to frame "ground."
2) Floated lighting coil: connect the yellow wire on the coil to the yellow wire on the regulator. Connect the other yellow wire on the coil to the white or pink wire on the regulator.
