Re: Vespa piaggio ciao 1967
Joe Runkle /
My USA stock 1968 Piaggio Ciao with duel filament brake light/running light with under frame reverse plunger style brake switch. The switch did not work and cut the ground current every time I pulled my rear brake causing the motor to die. I removed it and ground the blue wire to the motor and it corrected the problem but no longer have a brake light, just running light.
