Got a port map, turns out I didnt apply enough pressure XD. Now I'm thinking about doing some very basic ass porting after I rebuild. Thinking bout adding another base gasket so I have 2mm to get the transfers to 106°, then cut the crown 1mm down at the exhaust (if possible to go down that much) and get it to 153°, sand the head 1mm to get the squish back, and open a 2mm window at the intake to get 134°. Should be good?
