Re: Need advice - Minarelli V1
Daniel M /
> Satan 666 wrote:
> > Daniel M wrote:
> > > pat splat wrote:
> > > Hold on, are you putting oil in the gas?
> > The tank was half full when I got the moped, so I was working under
> the
> > assumption the previous owner knew what he was doing and had oil in
> the
> > gas. It does look clean though and doesn't smell foul. Would it really
> > have issues running without oil?
> Oil lubricates the engine. I would dump out the old fuel and put some
> fresh 50:1 mix in. 2.6 oz per gallon. Or just put 3 oz per gallon. Never
> trust anyone when it comes to used mopeds. Also does it have oil in the
> trans?
Yeah, it has oil in the trans. Per the manual, I tipped the bike over a few degrees with the drain screw removed and instantly saw oil come out so it looks to be full (and fresh too).
I think the fuel might be fine though. Instead of letting the thing idle for a while on the stand as I had been doing so far, I decided to get it started while peddling and see if I could ride it around the block a few times. It started without much of a fuss and I could indeed ride it around. But the idle issue still exists. If I let off the gas and try and coast, it just dies within a few seconds. And this seems to be the issue regardless of the position of the idle screw.
  Need advice - Minarelli V1Topic by: Daniel M Daniel M 09/06/21 12:11AM
  Re: Need advice - Minarelli V1Re: Beach Club Nick Beach Club Nick 09/06/21 01:03AM
  Re: Need advice - Minarelli V1Re: Joe K Joe K 09/06/21 07:16AM
  Re: Need advice - Minarelli V1Re: Ted Grant Ted Grant 09/06/21 09:09AM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/06/21 11:24AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/06/21 01:13PM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/06/21 02:04PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/06/21 01:00PM
  Re: Need advice - Minarelli V1Re: nate basch nate basch 09/06/21 02:05PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/08/21 12:37AM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/08/21 12:39PM
  Re: Need advice - Minarelli V1Re: Gen Xer Gen Xer 09/06/21 05:11PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/09/21 11:47PM
  Re: Need advice - Minarelli V1Re: kevy Piepkorn kevy Piepkorn 09/10/21 03:27PM
  Re: Need advice - Minarelli V1Re: Ryan Graeme Ryan Graeme 09/10/21 08:04PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/10/21 10:40PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/11/21 08:22AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/15/21 11:35PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/16/21 05:57AM
  Re: Need advice - Minarelli V1Re: pat splat pat splat 09/18/21 07:00AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/22/21 09:32PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/23/21 09:58AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/23/21 11:12PM
