Re: Need advice - Minarelli V1
Satan 666 /
> Daniel M wrote:
> > Satan 666 wrote:
> > Push forward like pedaling a bike. I usually trand put the pedal at
> > about 11 o'clock ,squeeze the clutch and kick. If it starts to run let
> > off the clutch. You should here the engine turn over the whole time.
> If
> > it slips when kicking then tighten up the clutch cable.
> Hmmm, sounds like I'm doing it right then. How can I discern if the
> clutch is slipping? Would a slipping clutch by identified by not hearing
> much of the engine turning over when peddling?
Yes. If you have the clutch engaged and are pedaling the engine should be turning over. If not then cable needs to be tightened. Can do so by turning the adjuster screw on the engine side of the cable. Most of the the time the cable has stretched.
  Need advice - Minarelli V1Topic by: Daniel M Daniel M 09/06/21 12:11AM
  Re: Need advice - Minarelli V1Re: Nick MBC Nick MBC 09/06/21 01:03AM
  Re: Need advice - Minarelli V1Re: Joe K Joe K 09/06/21 07:16AM
  Re: Need advice - Minarelli V1Re: Ted Grant Ted Grant 09/06/21 09:09AM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/06/21 11:24AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/06/21 01:13PM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/06/21 02:04PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/06/21 01:00PM
  Re: Need advice - Minarelli V1Re: nate basch nate basch 09/06/21 02:05PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/08/21 12:37AM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/08/21 12:39PM
  Re: Need advice - Minarelli V1Re: Gen Xer Gen Xer 09/06/21 05:11PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/09/21 11:47PM
  Re: Need advice - Minarelli V1Re: kevy Piepkorn kevy Piepkorn 09/10/21 03:27PM
  Re: Need advice - Minarelli V1Re: Ryan Graeme Ryan Graeme 09/10/21 08:04PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/10/21 10:40PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/11/21 08:22AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/15/21 11:35PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/16/21 05:57AM
  Re: Need advice - Minarelli V1Re: pat splat pat splat 09/18/21 07:00AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/22/21 09:32PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/23/21 09:58AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/23/21 11:12PM
