Re: Need advice - Minarelli V1
Daniel M /
> kevy Piepkorn Wrote:
> if it is oily, you can hang it up and try a torch,or poke somthing in
> the exhaust like a coat hanger .
It's not oily, on the outside at least. The inside looks to be a bit rusty, particularly the filter element around the opening in the center.I have a piece of wire thats about a foot long that I used to break up what seemed to be blocking the exhaust. I'm assuming there must be some crud in the filter element thats preventing the exhaust gasses from freely flowing out.
> Ryan Graeme Wrote:
> Chuck it on the BBQ or fire.
I'm a bit hesitant to do that. After tapping a spanner on the exhaust to loosen up some of the build up, I gently tapped the exhaust against a small tree trunk by the shed. To my surprised, it put a few dents in the exhaust! It must either be really rusted from the inside or a super thin metal. I'm afraid chucking it on a fire will cause even more damage...
Either way, I think the bigger issue I think is why it seems to die when the idle screw is backed off even a little bit from its highest rpm setting.
Stupid question, but which direction should the pedal be pushed to start the engine? Does it matter? The manual I was able to download states that pedaling first and then pulling the clutch should start the moped, so I've been kicking down on the right hand side pedal in a clockwise direction.
  Need advice - Minarelli V1Topic by: Daniel M Daniel M 09/06/21 12:11AM
  Re: Need advice - Minarelli V1Re: Nick MBC Nick MBC 09/06/21 01:03AM
  Re: Need advice - Minarelli V1Re: Joe K Joe K 09/06/21 07:16AM
  Re: Need advice - Minarelli V1Re: Ted Grant Ted Grant 09/06/21 09:09AM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/06/21 11:24AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/06/21 01:13PM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/06/21 02:04PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/06/21 01:00PM
  Re: Need advice - Minarelli V1Re: nate basch nate basch 09/06/21 02:05PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/08/21 12:37AM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/08/21 12:39PM
  Re: Need advice - Minarelli V1Re: Gen Xer Gen Xer 09/06/21 05:11PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/09/21 11:47PM
  Re: Need advice - Minarelli V1Re: kevy Piepkorn kevy Piepkorn 09/10/21 03:27PM
  Re: Need advice - Minarelli V1Re: Ryan Graeme Ryan Graeme 09/10/21 08:04PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/10/21 10:40PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/11/21 08:22AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/15/21 11:35PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/16/21 05:57AM
  Re: Need advice - Minarelli V1Re: pat splat pat splat 09/18/21 07:00AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/22/21 09:32PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/23/21 09:58AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/23/21 11:12PM
