Re: Need advice - Minarelli V1
Daniel M /
> nate basch Wrote:
> What's the clutch doin? How are you trying to start it? Cable, lever,
> the arm mechanic that's on the right side under the foot floorboards and
> then inside that right side cover has a "spring" 2 actually, little
> pieces of what look like sheet metal but I guess it's some type of
> spring steel they're stacked on top of each other one is a little longer
> than the other and they have a bend in them and then there's also the
> clutch material itself and then the little ball in the center which
> minarelli s are notorious for having wear flat and then they dont
> engage.
> Oh and also don't forget about the tail light thing. If the tail lights
> burned out the bike won't start I just took the bulb out and kind of
> hotwired my tail light take the red plastic cover off of the tail light
> and it's pretty simple but you'll see how the circuitry works It's
> little brass strips inside of there and also to do was take like a paper
> clip or a piece of tin foil or whatever and connect the one little
> zigzag strip to the next so I don't have a tail light anymore but the
> bike doesn't know that it thinks it works I just ended up spray painting
> my tail light cover black so you can't tell that it's burned out so the
> cops don't mess with me and it's been working fine ever since. Other
> than those things there from what you described I can't imagine what it
> might be It's got to be the timing or what I mentioned sadly I don't
> know s*** about the time and it's one of the few things on this bike I
> haven't messed with I've done points on my other bikes and stuff but
> never opened up that side of my minarelli
Not sure how to test the clutch to be honest. To start the engine, I engage the choke lever on the carb, hold the clutch lever on the left handlebar, give it some gas with the twist grip and then kick down on the pedal. And yes, I have the engine cut off switch set to the "off position".
If by the "right cover" you mean the one on the trans, opposite of the clutch then I havent popped that side open yet.
I actually have two bulbs on the back of my Safari. I inspected both earlier and the filament inside wasnt broken. But I might just bridge the two connections for the time being to eliminate the bulb being the issue. I might swing by the store to pick up a new bulb regardless though.
  Need advice - Minarelli V1Topic by: Daniel M Daniel M 09/06/21 12:11AM
  Re: Need advice - Minarelli V1Re: Nick MBC Nick MBC 09/06/21 01:03AM
  Re: Need advice - Minarelli V1Re: Joe K Joe K 09/06/21 07:16AM
  Re: Need advice - Minarelli V1Re: Ted Grant Ted Grant 09/06/21 09:09AM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/06/21 11:24AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/06/21 01:13PM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/06/21 02:04PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/06/21 01:00PM
  Re: Need advice - Minarelli V1Re: nate basch nate basch 09/06/21 02:05PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/08/21 12:37AM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/08/21 12:39PM
  Re: Need advice - Minarelli V1Re: Gen Xer Gen Xer 09/06/21 05:11PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/09/21 11:47PM
  Re: Need advice - Minarelli V1Re: kevy Piepkorn kevy Piepkorn 09/10/21 03:27PM
  Re: Need advice - Minarelli V1Re: Ryan Graeme Ryan Graeme 09/10/21 08:04PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/10/21 10:40PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/11/21 08:22AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/15/21 11:35PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/16/21 05:57AM
  Re: Need advice - Minarelli V1Re: pat splat pat splat 09/18/21 07:00AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/22/21 09:32PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/23/21 09:58AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/23/21 11:12PM
