Re: Need advice - Minarelli V1
Daniel M /
> baird co Wrote:
> There's two marks on the flywheel that line up with a mark on the case.
> Points should start to open at the first mark, and be fully open at the
> second.
> Simple way to time it is to stick a small screwdriver into the plug
> hole, rotate the flywheel till it's at top dead center, and check where
> the marks are. Should be lined up with the second mark on the flywheel,
> and points should be fully opened.
> Check point gap, make sure they're clean, and your condenser is good.
> You may have spark now, but it might not be timed right, or weak. I've
> had bikes that look like a good spark with the plug out, but won't fire
> under compression. You can buy a cheap inline spark tester with a light
> from harbor freight. I use mine all the time.
> And like above, check the exhaust. A clogged pipe will stop it from
> running.
> And check your kill switch, and your brakelight. v1's have a brake light
> coil that if the brake bulb blows, it won't start.
> Simple way to check is unplug the black and blue wires at the engine.
> Leave the black open and ground the blue. Leave the red one hooked to
> the coil. That's all you need to start it.
Thanks for the tips on timing. I'll take a look at the case and flywheel and see if I can find the marks, hopefully they are there. I'll go ahead and test the brake light bulb and the coil as you suggested.
Should I check the size of the points gap? If so, any idea what size it should be?
  Need advice - Minarelli V1Topic by: Daniel M Daniel M 09/06/21 12:11AM
  Re: Need advice - Minarelli V1Re: Nick MBC Nick MBC 09/06/21 01:03AM
  Re: Need advice - Minarelli V1Re: Joe K Joe K 09/06/21 07:16AM
  Re: Need advice - Minarelli V1Re: Ted Grant Ted Grant 09/06/21 09:09AM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/06/21 11:24AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/06/21 01:13PM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/06/21 02:04PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/06/21 01:00PM
  Re: Need advice - Minarelli V1Re: nate basch nate basch 09/06/21 02:05PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/08/21 12:37AM
  Re: Need advice - Minarelli V1Re: baird co baird co 09/08/21 12:39PM
  Re: Need advice - Minarelli V1Re: Gen Xer Gen Xer 09/06/21 05:11PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/09/21 11:47PM
  Re: Need advice - Minarelli V1Re: kevy Piepkorn kevy Piepkorn 09/10/21 03:27PM
  Re: Need advice - Minarelli V1Re: Ryan Graeme Ryan Graeme 09/10/21 08:04PM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/10/21 10:40PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/11/21 08:22AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/15/21 11:35PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/16/21 05:57AM
  Re: Need advice - Minarelli V1Re: pat splat pat splat 09/18/21 07:00AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/22/21 09:32PM
  Re: Need advice - Minarelli V1Re: Satan 666 Satan 666 09/23/21 09:58AM
  Re: Need advice - Minarelli V1Re: Daniel M Daniel M 09/23/21 11:12PM
