Re: Project Chavocado NC50 chop
Dick Chavez /
The little Honda express chopper is coming together.
I picked up an old sportsman cooler and an old coca-cola crate last weekend and cut the crate to the demension I wanted to fit the beer cooler perfectly.
Also got to work building the fuel tank, I would normally calculate the capacity while planning what I was doing but as part of my have fun first and ask questions later excercise I started making and ended up with a 1/3 gallon tank. My town is only 1 square miles and all the roads leaving are 55mph so by time I run out of beer I'll have to return home to refill the gas and the cooler.
I also have the parts on the way to hopefully fix it. New meteor piston kit, 1mm cylinder spacer, 15.15 sha, jet kit, slide, hobbit jammy pipe and that should solve my 90 psi of compression.
