Got the crank seal replaced, new crankcase gasket, exhaust gasket, and grade 8 bolts instead of screws, cylinder/head all new gaskets and plug replaced. Also switched out the carb and made some adjustments to it. It cranks on first kick now and idles well. Have yet to run it due to storms to see if it loses power.
This bike came without the stock airbox installed. Does anyone know how the hell those go back on? Is it over the axle and between the back wheel and frame? There’s a brake line, oil line etc in that same spot.
