I have a qt50 that idles fine but under load smokes like crazy and will lose power, after a few seconds will be good to ride a short distance then do same. I’m leaning towards right crank seal at this point but wanted to see if anyone here might have fixed something similar.
Compression = 90psi
Also, it looks like prior owner may have broke an exhaust bolt off in the cylinder so instead of fixing it the right way they jb welded the damn exhaust to the cylinder. Which means to even get to the crank seal I have to fix this first. So to get the muffler off the entire cylinder needs to come off. Since I have to do all this now anyway, are there any good replacement cylinders and piston kits? May just replace that stuff while its off.
Thanks
