Re: Would you run a 3d printed light lens?
If you did your calculations right it should be feasible to print a rough fresnel.... the individual rings of the lens would need to be matched to the nozzle on the printer....
Terbo Speghetti /
Yeah, probably. But my question is why would you? A parabolic reflector accomplishes the same thing with a lot less work and engineering.
Fresnel lenses are great for lighthouses and stuff, but not practical on such a small scale imho
Dirty30 Dillon /
> such a small scale
Every efficient modern tungsten/HMI light has both a parabolic reflector and a fresnel lens, even down to 2" elements. The two definitely work great in conjunction.
But I won't argue that designing a purpose built fresnel is hard. There's big dollars in good fixture design.
I have a pile of old, stripped Mole-Richardson and Arri Fresnels at work, and I've always wanted to convert one to 12VDC to run as a head light just for shits and giggles.
One with wide beam and one focused to narrow beam.
♣Slew Foot♣ /
Lenticular are different how?
That's a buety now run a van de Graff off the variator...
Terbo Speghetti /
> be
> reflector
> on
> > such a small scale
You did see that I made a tail light and not a headlight, right?
♣Slew Foot♣ /
Yep.
3d printer ? Could you add a z axis cradle and do light machining passes?
Terbo Speghetti /
> ♣Slew Foot♣ Wrote:
> Yep.
> passes?
You*could* do anything. But no.
Dirty30 Dillon /
> a
> > be
> > reflector
> practical
> > on
> > > such a small scale
> reflector
Yes.
Lenticular or fresnel style moldings would just boost output, is all I am aiming to convey. I don't think it will make or break the functionality of the design, either way.
♣Slew Foot♣ /
Tractor lights work awesome but the angle is too wide if you raised the tractor style pylons and steepend the angle to 120 instead of the 170...
