Re: Is this moped worth restoring?
Totally normal JBOT /
The piston looks bad but is probably fine.
Usually I would take the rings off and sand a bit of the piston where the scoring is to get off any high spots, then wash well with dish soap then put back on lubed rings and you’re ready to go. Just be careful taking off the rings. You pry em open just enough to get off the top of the piston (edited)
  Is this moped worth restoring?Topic by: Nicholas Smith Nicholas Smith 04/06/21 12:38PM
  Re: Is this moped worth restoring?Re: Bas Autowas Bas Autowas 04/06/21 12:57PM
  Re: Is this moped worth restoring?Re: Nicholas Smith Nicholas Smith 04/06/21 01:13PM
  Re: Is this moped worth restoring?Re: Totally normal JBOT Totally normal JBOT 04/06/21 01:23PM
  Re: Is this moped worth restoring?Re: Nicholas Smith Nicholas Smith 04/06/21 01:28PM
  Re: Is this moped worth restoring?Re: Nicholas Smith Nicholas Smith 04/06/21 01:49PM
  Re: Is this moped worth restoring?Re: b to the eff b to the eff 04/06/21 02:10PM
  Re: Is this moped worth restoring?Re: Frank Bailey Frank Bailey 04/06/21 03:01PM
  Re: Is this moped worth restoring?Re: Nicholas Smith Nicholas Smith 04/06/21 08:07PM
  Re: Is this moped worth restoring?Re: Totally normal JBOT Totally normal JBOT 04/06/21 01:10PM
  Re: Is this moped worth restoring?Re: Nicholas Smith Nicholas Smith 04/06/21 03:14PM
  Re: Is this moped worth restoring?Re: Nicholas Smith Nicholas Smith 04/06/21 03:17PM
  Re: Is this moped worth restoring?Re: Bas Autowas Bas Autowas 04/06/21 03:21PM
  Re: Is this moped worth restoring?Re: Trent Anderson Trent Anderson 04/06/21 03:56PM
  Re: Is this moped worth restoring?Re: Totally normal JBOT Totally normal JBOT 04/06/21 08:45PM
  Re: Is this moped worth restoring?Re: Jesse Nordlander Jesse Nordlander 04/06/21 10:14PM
  Re: Is this moped worth restoring?Re: Born to be WillD Born to be WillD 04/07/21 09:42AM
  Re: Is this moped worth restoring?Re: Scottie Hartpence Scottie Hartpence 04/11/21 07:51PM
