> Nicholas Smith Wrote:
> I sanded the points and gapped them, and checked the resistance. It's
> zero when closed and 1.2 ish ohms at TDC. I spun the flywheel with a
> drill and an arc actually jumped the gaps between the points. Is this
> good or bad? What should I do from here to try to get spark at the plug?
Assuming you have the coil and spark plug connected, you should not see arcing across the points.
The most usual cause is a bad condenser. Replacements are cheap and readily available.
