Anyone have a scan for a puch 70cc airsal cylinder 45mm base gasket, waiting for the kit so a base gasket scan or something like it is needed to do some port matching .
Thank You much
Thank You much
wait for the kit.you can take metal off but you cant put it back on pal
Haha yup
Edit: run it uncased matched (edited)
It is also better to do a match with the case still in halves so you can mate them up with the cylinder to check the flow/transition of tour work easier.
Thank you all for the info but I'm hurting back bad again so this is on hold for a few days.
you'll get your 40 without case matching
