Re: Back on Trac
J o h n /
The case side transmission shaft bearing is a 6201
The output shaft bearing (not pictured, no code) is a 6202 bearing.
The bearing inside the transmission gear is an HF2520 One way bearing.
Internal end output shaft bearing is an HK1812 bearing.
I know it’s not much to start off with, but it’s something. The only two I don’t have sizes for are the connecting rod small end bearing and the clutch bell one way bearing. My cheap-o calipers tell me random distances completely unrelated to the measurements I’m actually taking all of a sudden. Must be the humidity. Oh well. I’ll get seals up tomorrow.
