chopper build
i’ve been wanting to make a chopper for a while but being on an uncommon base (columbia commuter) it didn’t really feel like a doable thing. over this winter i’ve decided to go into it for real and im starting at the forks. i got some tubing that’s the exact size as my fork tubes and cut it to be about 16” extended from the stock forks. i compressed the bottoms to be flat for the wheel mounting point and drilled out for the axle. at this point i am waiting for access to a welder. either at my school shop or from a buddy. i need to chop the spring mounting point off of the old fork legs and butt weld (tig most likely) them to the new fork legs. i figure since it is covered by the fork “sleeves” that butt weld should hold up fine.
stock handlebars after bending
stock fork legs around the length that i wanted just to get a feel for the style
new fork legs next to old
Re: chopper build
new fork legs mocked up. still missing the springs though
Re: chopper build
forks are now in. trying to figure out what to do for the seat. anyone have any ideas?
Re: chopper build
Beach Club Nick /
You are most definitely going to want to add some sort of cross brace on the fork lowers. Also with that rake your front wheel is almost definitely going to skip/hop when you brake. Just thing to keep in mind
Re: chopper build
Just dont use a front brake. Most chopper guys dont run them.
Re: chopper build
that is a really good point about the fork brace - completely slipped my mind. i have some aluminum on the way to make one (hopefully). also thanks for the heads up about the braking, i’ll be running no front brake so it’s not a huge worry but i do appreciate the warning
Re: chopper build
> have any ideas?
Treats sells chopper seats for maxi bikes.
Re: chopper build
what schedule tubing?
I'm a little nervous but I would also do the same thing - looks good on that frame too IMO
Re: chopper build
Alex Fredericksen /
Chop the head tube and adjust the rake. No one ever gets this on a "chopper Ped".
Re: chopper build
> that frame too IMO
it’s mild steel .065 inch wall. it’s from a racing supplier so i’m not worried about it at all. i appreciate the concern tho
in other news here is the fork brace i designed, i just have to get it 3D printed in nylon
Re: chopper build
I wouldn't trust nylon. You can just get a ebr fork brace and that will work perfect. That fork brace you designed wont stop the twist effect unless you through bolt it to the fork tubes but the nylon is a bad idea. Also is the tubing DOM tubing?
Re: chopper build
https://www.summitracing.com/parts/sum-tr1000-065-4 this is the tubing i got. with the ebr brace i would have to make mounts though right?
Re: chopper build
the tubing that i gots wall is the same size as the original fork tubes wall
Re: chopper build
> zack reep Wrote:
> will
Yes just like the stock ones. If you cant weld I'm sure you could bring them to a muffler shop all prepped and they can zap them. Or welding will make mopeds so much more enjoyable so go buy a cheap welder and have fun.
Re: chopper build
Totally normal JBOT /
Omg the only other Columbia sport I’ve ever seen! Cool!
WAit, a Columbia supreme? Lol wtf Columbia. (edited)
Re: chopper build
How did you get out the original fork legs? Do they screw out?
Re: chopper build
> Satan 666 Wrote:
> > zack reep Wrote:
> > will
> effect
> i
> have fun.
cool i’ll look into it more. i’m currently in school getting an associates in welding technology so i can just weld stuff up at school
Re: chopper build
yep! they screw right out
Re: chopper build
apologies for the lack of updates. it was real cold here in michigan and as it was warming up i stabbed my palm w an exacto knife working on modifying a pull start so i’m out of the game for a few days (maybe more if i need surgery :/). i’ve got a fork brace to fit up though and a pull start to finish up as soon as i’m back
Re: chopper build
fork brace is on (along with a new throttle)! the steering is a little off but i don’t really care. if it becomes an issue i’ll fix it. borrowed my friends welder for the brackets. this whole thing is making me wish i had a tig machine but man are they expensive. i’m going in for surgery tomorrow too so i am unaware of the frequency of coming updates but i’ll do my best. it’s starting to warm up too so once i heal up i can ride soon 🤞
Re: chopper build
Issa choppa
Re: chopper build
Damn right it is. Badass!
Re: chopper build
damn, you dont have a welder but those are your welds?
you obv know what you're doing, get a fuckin welder geez
Re: chopper build
thanks guys!
looooool it’s on the list i appreciate the kind words :)
Re: chopper build
update time! i pulled the engine out to disengage the pedal shaft and take out the starter clutch. while i had it off i fixed my timing. i followed the moped luau tutorial and made a pull start which worked great until i broke it so i’m now waiting on another in the mail.
i got the wiring all figured out with two switches tucked into the headlight (kill and lights).
i figured i’m going to upholster the seat on it in the photos for a comfier ride.
i also put the foot brake on which is decent
Re: chopper build
alright
not entirely sure what you're doing inside the engine there but pullstart is a thing you could do, sure. and not having pedals, ok... but you should probably rig the back brake to a foot pedal of some kind for fun
Re: chopper build
back brake is a foot brake! using this. in the transmission i took out the gear that connects the pedal shaft to the main gear to cut down on the vibration of the pedals at high rpms (edited)
Re: chopper build
threw some foam on the seat and shaped it to my liking
this is the seat after upholstering. a little sloppy but it’ll work for now. it was my first time. i may cut another one in the future and send it off to someone to upholster it for me, well see.
this is how she looks as of now - i need to make an exhaust bracket and tighten up the rear wheel still
Re: chopper build
got the bike out on the road today. feels great! i lost spark though so i’ll be working that out. i was worried the forks would be super difficult but they aren’t bad at all compared to a heavy motorcycle chopper
Re: chopper build
welded these up at school today. a little sloppy but so much fun
