Save this web page you Bingheads
Tri-ped Dave O.D.B. /
I have seen so many requests for info on so many different bing carbs over the years on this forum. Well....here is the factory settings and specs for like every bing made no matter how bizarre. Just find your type in the drop down menu.
Yes I know this should be in the tuning forum but so many (like me) never go there and stick with general forum because it is way more highly populated.
https://www.bingpower.de/en/service/tuning-manuals
Re: Save this web page you Bingheads
It gives you all the stock jet sizes, the atomizer, every possible bit of info on that model carb. It has the specs for about 100 different Bingos
Help out a newby - how do I figure out which carb I have? I'm pretty sure I have a 12mm square bing but what does that correspond to in the list?
I believe all (original) bings have their model stamped in this location. Mine says 1/12/203a, the 12 stands for 12mm so yours should also have a 12 in the middle.
Look at it. The model number is stamped on the carb. Here's an example of a 15mm square Bing sold at treats (edited)
This link is already part of the Moped Wiki article on Bings.
https://mopedarmy.com/wiki/Bing
The wiki is down. Has been for a bit.
Thanks, I'll check it out!
Incorrect.
The wiki is in read-only mode during the current upgrade, but the above page loads just fine.
> Incorrect.
I get the following when trying to load any wiki page. Not sure what I'm doing wrong but it sure seems like a back end error.
The Wiki loads fine for me .
I dunno man, ask Simon. The wiki loads just fine for me too.
You can start troubleshooting by trying a different browser or rebooting your PC. (edited)
Luke ,
You might try emptying your cache and reloading the page .
Hold control when you click the refresh on the page after getting the error. That will clear the cashe for that page and give you a hard reload of it. Otherwise use chrome.
I think it is because you have reached your porn threshold, all other pages just become random letters.
