6v to 12v help
Hey all! Recent moped purchase, engine is a sachs 505 clone. All the lights are broken and it's cheaper/easier to replace with LED's all around. Problem there is I need 12v DC not the 6v AC that's currently on the bike.
It has a (dead) battery but when I measured this morning I was getting from 4-10v AC from the wire leading to the battery - varying with throttle input. So first and foremost I think the old silicon rectifier might be bad.
My plan WAS to use a 6v rectifier/regulator to get a solid 6v DC out of the system, then hook that up to a 6v battery and use a 6v DC to 12v DC convertor to power the lights on the bike. I also thought about using a small 12v battery pack (NiMH or something) to help ease the load on the converter.
But someone mentioned I could just swap the coil and get 12v on the whole system - would I need something like this? What else would I need?
I'm usually good with wiring but this whole thing is confusing me for some reason. Thanks all!
Re: 6v to 12v help
I think the problem with all that is power loss through conversion as well. The best bet would be probably be buy a rectifier and rock 6vDC lights or buy a whole CDI setup. Really though batteries last FOREVER so if you keep the lights on
12v battery only and throw a $30 minder on it when you park the bike you're chillin'
Re: 6v to 12v help
Dirty30 Dillon /
Yeah, you're going to loose output by trying to use a voltage doubler.
If the system had a battery, than it must have a way of outputting dc from the factory. You cannot power a battery with AC current.
Re: 6v to 12v help
> you're chillin'
Already have 2 chargers so this might be the best idea of all. Just throw on a 12v battery where the old 6v used to be and voila!
Is there anything wired into the battery that won't work on 12v - so long as I replace all the lights? My moped doesn't have a published wiring diagram so I'm working kinda blind. (edited)
Re: 6v to 12v help
You're right. But when reading the voltage using to the only wire running to the + terminal on the battery using my autosensing voltmeter I was getting AC current.
Do you think replacing the old rectifier would fix that? Or would it be easiest to just throw on a 12v battery to power everything and charge it when needed?
Re: 6v to 12v help
> so
> > you're chillin'
I already have a 12v horn and a 12v flasher relay so those are good to go. I wonder about the stop switches.
