Re: 6v to 12v help
Luke Vidacovich /
> Dirty30 Dillon Wrote:
> Yeah, you're going to loose output by trying to use a voltage doubler.
> If the system had a battery, than it must have a way of outputting dc
> from the factory. You cannot power a battery with AC current.
You're right. But when reading the voltage using to the only wire running to the + terminal on the battery using my autosensing voltmeter I was getting AC current.
Do you think replacing the old rectifier would fix that? Or would it be easiest to just throw on a 12v battery to power everything and charge it when needed?
