Easy sha intake
So I was digging through some boxes and found some old home made sha intake parts so I figured I would share. So it's just regular old 1/2" electric conduit. It fits some sha bushings very well. I have a tight radius bender so I can make an pretty good bend with the crap. You can also cut and weld how ever you want. Its 15mm inside so that's cool. I also just get a big ass washer and cut to fit and weld to the washer. I then use a belt grinder or if you dont have one you can get some sandpaper and a nice flat surface and sand away to make flat. Very cheap and easy
Re: Easy sha intake
Here is a finished product that is on an engine and has been well used. Made this many years ago and has held up well
Re: Easy sha intake
Noice!
Re: Easy sha intake
Well done, what is the inside like, smooth?
Re: Easy sha intake
Be careful welding that stuff, the gasses emitted can kill you if you aren't careful.
Re: Easy sha intake
Probably Fred /
> aren't careful.
Zinc, cadmium and other poisonings
Re: Easy sha intake
> aren't careful.
Oh yeah. I always grind back the galvanized coating. It has got me before. Wont kill you but will make you sick. I had to drink a bunch of milk. When you weld galvanizing it floats through the air lie little snowflakes. I wear a miller respirator under my helmet alot when welding also. Welding in general can kill you slowly over time
Re: Easy sha intake
Yeah pretty smooth. Fits the sha bushing realy well. If you put a few coats of paint on it it fits real snug.
Re: Easy sha intake
this is great, really like the idea of using a large washer. ive been making them with flat stock and its always a pain to bore out a hole. this is one i made for a 15.15 SHA using 3/4 pipe on a demm smiley.
Re: Easy sha intake
You can use flat stock also. Go to harbor freight and get the cheap step bits they have. I almost only use them now for drilling steel. They cut nice when new.
Re: Easy sha intake
From the first pic I thought it was rubber tubing, I thought how awesome that would look cruising down the street with your long rubber dick intake carb flapping in the breeze.
Re: Easy sha intake
Haha
Re: Easy sha intake
Rubber dick intake! Dude that is some funny shit right there! Anyone know where to get a bell shaped air filter?!
Re: Easy sha intake
Yeah treats sells the "alien" filters. They look close enough. Or a metal mesh filter for a bing looks the part.
