Re: Running poorly. 1994 Tomos a35 14:12 carb.
♣Slew Foot♣ /
The shim is inside the carb throat the o ring is before the shim where the clamp bolt is there are 2 areas one before the clamp on the top other is that split. After that. Make sure that the slider bottoms far enough. The. Holes in the tube of the carb are clogged the jet fell out or is clogged the cdi ground wire or spark cap is bad the killswitch is grounding itermitantly wrong plug heat try a 6 hs.
  Running poorly. 1994 Tomos a35 14:12 carb.Topic by: Charles Fowler Charles Fowler 01/24/21 02:54PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Charles Fowler Charles Fowler 01/24/21 02:56PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Nick MBC Nick MBC 01/24/21 03:02PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Charles Fowler Charles Fowler 01/24/21 03:16PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Nick MBC Nick MBC 01/24/21 03:19PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Charles Fowler Charles Fowler 01/24/21 04:22PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: ♣Slew Foot♣ ♣Slew Foot♣ 01/24/21 04:36PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Charles Fowler Charles Fowler 01/24/21 03:17PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Saabsonettguy . Saabsonettguy . 01/24/21 03:10PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Charles Fowler Charles Fowler 01/24/21 03:18PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Charles Fowler Charles Fowler 01/24/21 04:25PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: ♣Slew Foot♣ ♣Slew Foot♣ 01/24/21 03:25PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Charles Fowler Charles Fowler 01/24/21 04:24PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Charles Fowler Charles Fowler 01/24/21 04:30PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: ♣Slew Foot♣ ♣Slew Foot♣ 01/24/21 04:38PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Charles Fowler Charles Fowler 01/24/21 05:11PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Charles Fowler Charles Fowler 01/24/21 05:09PM
  Re: Running poorly. 1994 Tomos a35 14:12 carb.Re: Jay Rivett Jay Rivett 01/26/21 11:24AM
