Re: Qt50 build progress!
Jack Rutherford /
nice work! that was a bit of sanding
mark voznyuk /
yeah, in reality it was pretty quick, took about 40ish minutes with the die grinder, due to me putting on the cylinder and my half-assed die grinder skills lol
you don't need to sand that much, i just did it because my die grinder wouldn't fit flush. (edited)
Wow, you are sure making up for all the time that bike sat idle! :) Looking good!
mark voznyuk /
Yup, hoping for a more RPM out of this kit as i know the 2 stroke scooter engines run 10k+ regularly.
Ill need to match the cases heavily and clean up the ports, hoping on seeing a lot more power out if it once im done. (edited)
Looks like just that top cylinder fin got busted off .
I'd run it and wouldn't worry much about it as the head will dissipate the majority of heat .
mark voznyuk /
ayy! Didn't bail just yet!!
Currently, JB welding the other half of the case since id like to get a better surface for sealing, plus the ability to actually match the transfer ports to the MAX!
(ignore the dust and metal shavings plz) (edited)
mark voznyuk /
Alrighty!
Sanded the jb weld flat enough, ported the bottom end (conservatively)
Made my own custom cork gasket and slapped on a jog pipe!
Had to cut the mounts of the pipe, however, bailing wire works just as well ;)
Pulls HARD on the top end (too fast for 2in brakes)
Top end is roughly 50-55mph.
Too fast yo!
(yes, spark plug cap is falling off, i know) (edited)
Rad! I bet this has ALL the torque. :-)
mark voznyuk /
Oh yeah, once you get above 10mph it just goes!
Pipe and kit seems to be perfect for the budget basher setup. All and all I've got under 80$ in the top end AND pipe.
Possibly get a liquid cooled setup in the future ;)
That's awesome! Does the battery absorb the extra voltage and save the bulbs?
> punkrock randy wrote:
> I don’t think I’d ever wanna part w Champ. ‘Specially now that I’ve got
> my bier hauling solution sussed out!🤙🏼 Now to get that damned next level
> pipe mounted up🤔
Did you get an exhaust put on?
I had a really good idea for my QT50 project back in the day. My idea was to remove the gas tank from the frame run a bar like a top tank and run it like a top tank it'll be nice and low to the ground and I think would look really cool. Good job with your build but I like your exhaust
^ Someone has done just that....it was posted here years ago, it looked REALLY good.
