1978 Batavus (Laura M56) Ratchet Wheel Replacement
Working on a Batavus with the Laura M56 engine, and I need to remove the ratchet wheel. The manual says I need special tool 565005. I’ve tried to search for one online, but no luck. Do you have any thoughts as to how to proceed for removal?
Re: 1978 Batavus (Laura M56) Ratchet Wheel Replacement
weird, so the sprocket screws onto the ratchet wheel?
I have a pretty complete m56 id sell for 120 shipped if your interested.
♣Slew Foot♣ /
Looks like the chain could hold it whilst you turn it it looks like it just holds the sprocket so you can loosen a nut or bolt.
Jody Greene /
I was able to disassemble, however, the method I used probably wasn't the best option.
1. Clamped vice grips on the ratchet wheel (perpendicular)
2. Clamped the vice grips in a vice so that the ratchet wheel would not spin
3. Rapped the chain around the sprocket and used a wrench to unthread the sprocket from the ratchet wheel.
I needed to use a cheater bar to provide enough force, but it eventually came off. No damage.
Whatever works .
It's just mopeds . ;)
yeah, necessity is the mother if all creation. good job, post a coupla picts for future reference. and details ccw or clock wise etc
