Piaggio si oil rear mozzo air exit
Valentin Mishu /
Hello i guys , i have mounted my rear pinasco mozzo with 11 to 1 ratio shatfs inside i have put around 65ml transmision oil inside . Polini high speed front vario engine polini d46....and when i push more then 55 kmh it spits litle oil on the air exit port of the mozzo...the one responsabile for high pressure i think that takes air out..now oil goes out there also...
i think only the extra oil ?
its not normal ? or its ok until it remains the corect amount of oil inside?
Thank you , Valentin
