Re: SECRET REPAIR TIPS YOU DON'T TELL TO THE PEOPLE FROM MOPED ARMY
Johnny Braaapp /
> actually, anyone use those tire changing stands? Seriously I change like
> 80% of the tires in our shop and I've never used the stand. I don't even
> know how it should work. I gues I could watch a youtube.
> I think it's this thing. I don't fuck with it. maybe its for cars only?
> https://shop.harborfreight.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/6/9/69686_W3.jpg
No. Especially on moped tires. They're basically the same as a BMX bike which, for me require no tire irons. One thing I took out of that video that I'll try next time is to throw a tire down to use as a "work bench." Just takes some elbow grease, definitely you do not need ANY fucking special stand.
Double Trouble Dan /
You have a bike that will not run or not running properly .
After checking fuel supply , spark , and compression , you decide to check the points and timing .
If your timing will not set properly after setting the points to the correct open measurement ( + - .016) and you can get the bike to run with the points almost closed (.010 or less) and the stator plate set to fully retard the timing , the flywheel cam rub block on the points is worn out and they need to be replaced .
I have had several bikes with this condition lately . Easy fix once i found it .
♣Slew Foot♣ /
I will just reset the points at fully closed if that feeler is shot just to run it till parts get there.
