Honda pa 50 idels but wont run
Hi I have A honda 1978 pa 50 it idels but when you give it gas
it boggs and dies.ive cleaned the carb several times the needel and float seem to be working should i look for a new carb or repair kit if ones available.I love my ped Help please............
Re: Honda pa 50 idels but wont run
ItsLookingUp /
Sounds like a carb problem. When was the last time it was cleaned? Is the tank rust free?
did you clean the carb properply and make sure every passageway was clean?
when that happened on my dirtbike, the main jet was totally blocked, and only the idle jet was working. if your carb has an idle jet, i'd say that this is your probleb. if it doesn't, still clean your carb :)
