piaggio si flywheel sound
Valentin Mishu /
Hello , i have this sound on my piaggio si electronic ignition does everioane knows from where it its...i have changed the krankshaft bearings...piston rings...no effect , the crazy sound stil hears..i cannont attach video...its something like a hard paper on your bicycle spoke...
Thank you , Valentin
Re: piaggio si flywheel sound
Terbo Speghetti /
Could it be your fan scraping the inside of the fan cowl? Can you put up a photo at least?
Valentin Mishu /
Yes to the fan scrape. Sometimes when you mount you motor back in the brake cable gets trapped between the fan shroud and subframe pushing the shroud into the fan
