> PJ Murphy Wrote:
> This is what the owners manual states:
> OIL LEVEL IN REAR HUB
> Before using the vehicle check there is
> oil in the rear hub (co·ntent: 2 fl. oz.) GB
> when the machine is upright the oil lever· must be level with the· lower
> edge
> of the refuelling hole
Right so that's the transmission, not the brakes. You need a little bit of gear oil in there, there's a bolt on the side that gear oil should trickle out of when it's full. Unless I'm thinking of Honda Hobbits and Vespa's aren't like that
