Tomos Sprint A35 Fill Level Bolt Stripped
Benjamin Wheeler /
I picked up a 04 Tomos this summer and just changed the transmission fluid this afternoon. After I drained it I discovered the fill level bolt was stripped...and I couldn't get the bolt out to determine the proper fill level. I replaced the same amount of ATF (type f) that was removed, which was around 7oz or so. Any advice on how much ATF I should be using? Thoughts on trying to replace the fill bolt? Thanks!
Ben
