Re: Mysterious Flexer Behavior On A Longer Ride
Bas Autowas /
If you pull the flywheel off and look at the base plate, there is a dot on there. If the dot is pointing at the bottom line (left to it) it is on "30kmh mode" you can loosen the base plate and turn it clockwise to advance timing and that should help performance. Some people say to completely turn it to the top line, some people say that depends on your setup.
Sorry for the kinda crappy description, but describing these things in English isn't my strong suit.
