Re: Treats Bing clones VS Ebay Bing clones
Probably Fred /
I’m with Graham, I went through dozens 14 mm bings over years, they are great for mild piston port kits/cylinder builds, they make close same power as a 15 mm bing depending on pipe and cold start is better then 15mm bing on pp kits some times times too.
I do prefer the 15 mm bing with certain kits/reed kits/builds over the 14mm bing though a lotta times I try out both carbs to see which one works better like I’m doing right now to get best mpg to power
