plug fouling out{ Puch}
i have spark,but as soon as i put the plug back in it will start for a min.then fouls out.The plug is black. i cut back on fuel ratio and still does it. 3cap per gal.
thanx Dan
RE: plug fouling out{ Puch}
Ron Brown /
Dan,
Your problem is not too much oil, it is too much fuel/oil mix relative to the amount of air. You could have a sticky or sunk float or a blocked air passage in the carb or your choke could be partially on. If you have an idle mixture adjustment, this could be set too rich.
Ron
mopeddler /
you need to rebuild your carb (new float,needle, gasket}. i have a moped store and would be glad to send you any puch parts you need. you can also call my store and talk to my puch expert dave.941-627-6600. or email me at gcamp@cs.com
