Re: Resetting Vespa flywheel
Dirty30 Dillon /
Les, I'm guessing your saying that the woodruff is not seating properly? Vespas can be kinda hard, given the tight tolerances between the flyweight and casing, so I have found a little dab of CA glue is pretty useful when get a overly loose key into the way. It typically doesn't survive the engine heat, so it's not even a bear to remove.
