CORNFLAKES,DERBI SL,FR,FDS,RITO,DUAL SHA,POLARIS,ETC.
todd amundson /
This is my Cornflakes bike. If you look at a box of Cornflakes you'll see it. Tyler left this 1978 SL roller with me when he moved north to SAC. I've had it for at least three years and have finished the build. It's quick, real quick, does wheelies and all that BS. It's most comfortable at 35-40. I like just cruisin with my feet on the floorboards.
Dual SHA carbs 14.14 bottom, 15.15 top
Derbi FDS Gila Kit for upright motor 43mm stroke
Puch Rito rod with Yamaha JOG trans shaft welded on
Polaris 90 rear pulley and clutch bell 112mm, 110mm clutch
Super modified Polini front variator with Chinese fan pulley
TPR head and Polini radiator from Diablo project that went AC
Puch Condor exhaust
Derbi Box rims
LEM 50 front end
Re: CORNFLAKES,DERBI SL,FR,FDS,RITO,DUAL SHA,POLARIS,ETC.
Totally normal JBOT /
That’s an awesome scooter
Dude holy shit
*Italian chefs kiss*
Wow, nice!
nice job Todd.
love the 1990's nerf blaster aesthetic.
Is the Derbi vertical FDS JB Weld cylinder a stop gap from using a kid's dirt bike cylinder?
Cornflakes ... you're too modest .
More like Frosted Flakes , cause it's Grrrreat . ;)
Seriously , nice clean build with just enough .
Dirty30 Dillon /
Finally, a cool thing
Cornflakes: because it runs good for 5 minutes, then gets all soggy.
Just kidding.
This bike is a breath of fresh air. I’m inspired by your creativity, ability, and tools.
Everything just looks so solid. Like, most mopeds you can grab onto stuff and just flex and wiggle. Not so with Cornflakes.
Did you use freeze plugs for the pedal shaft and detent seals?
todd amundson /
Yes those are metric freeze plugs. Some Mazda junk. Pedal shaft is cut short but still rides on the drawn cup bearings. If you leave the shaft seals in place it’s kind of a waist.
todd amundson /
Hi someone asked how I got the front variator to come to a stop on a shoulder that's .5 mm in hight. There's a groove that I assume is 15mm OD so I double stacked two circlips, cut the teeth out of the ramp plate and welded a support ring directly to the plate. As the mounting nut tightens down, the circlips will be pushed against the hairline shoulder and want to expand out but can't. Kinda sketch but works great. The teeth on the ramp plate would not allow the front assembly to go inbound all the way which is what you want on this set up. Front as close to case as possible, rear as far from case as possible.
Tester washer
Yum! Looks fun.
Love the headlight tooooo
Damn that's a sweet build.
Screw the bike how is nobody talking about the sweeeeet pink windbreaker.
Emil Kniemel /
I didn't see the beak right away. good shit. red grips will set it off.
One more question, How did you ever fit that crank in the flatreed?
todd amundson /
Puch cranks are obviously narrower and have smaller cheeks so going in it fits but, the bearings need to be spaced out about 1.5 mm on each side and I’m using 17mm I’d bearings in the case The jog output is normally 19mm od but when machining the shaft to press into the crank, for some reason I made it 17mm.
Case volume isn’t much of a problemo as of yet. Maybe causes a little gulp at low rpm but I haven’t been able to verify.
todd amundson /
Got my new swingarm from treats. It’s aluminum and is the later style with webbing and no brake stay. I welded a stay tab to my caliper mount and attached a gusset. This is my first rear mount caliper on top of the rotor. There’s a good reason why it should be mounted under the swingarm and I’ll stick to it in the future.
Beach Club Nick /
What is the good reason for it to be mounted under the swingarm
todd amundson /
The swing of the caliper mount should be pulling on the the brake stay as opposed to pushing it as I have. Easier to break in my configuration.
Holy fuck. I don't understand the caliper mounting thing, even though you explained it out, but is that how the swingarm broke?
todd amundson /
When braking the rotor will push the caliper forward towards the front of the bike. My gusset stops this forward push. A broken gusset bolt caused the break before. It’s better to have a caliper gusset pulling on the assembly instead of pushing on an assembly.
Dang that is crazy the swing arm broke. Glad you are ok. If something like that happen to a bike my wife was riding on she would had been toast.
Downhill Harvey (OFMC) /
pls pls pls tell us where you got those adjustable brake end doohickeys!!
Is that the same crank we did years ago for your variated puch?
this thing
todd amundson /
Sure is Tyler. I remember you taking that picture on the day you and a friend rolled through. It was that night my cctv caught you sneaking up on me. You asked if it was like a $400 crank now and I pretty much agreed. I never figured out how to put a jog 90 crank inside or what ignition taper they have. That’s the true Derbi tuning shit.
Woah, that's wild
How did you guys weld that crank? That's some next level voodoo shit
Beautiful bike man ! Nice pic of president Carter as well
todd amundson /
> doohickeys!!
They come on some cheap Chinese brake cables from amazon but Jawa uses the same.
