Re: Can I use a front tire (NR77U) in the rear on qt50?
Jack Rutherford /
The rear version of that tire is too wide for the Qt50 so that’s your only option. You can use it on the rear no problem. I don’t see any difference in the tread between front and rear and on a stock qt you will going less than 1/3 of that tire’s speed rating. (edited)
